Three fuel injected 302 intakes upper, and lower no throttle body. $40.00 for a set of upper and lower. Can port and polish if desired price then $150.00
Pro comp 4 inch lift springs, and shock front and rear (not dual shock package) Not mine but posting for a guy $100.00 used for about one month no sag.
Big block c-6 transmission came from behind 460 complete torque converter and all two wheel drive unknown working condition.
$50.00
352 fe v-8 Casting number c6me-a missing rocker shafts but have another set that can be included just not installed has cast iron 4bbl manifold and a comp cam recently rebuilt heads i have never run it unknown condition. Complete $125.00 intake $35.00, valve covers $25.00
Dash parts 80-86 with factory tach cluster and trim, and 95 explorer ranger with factory tach. $15.00
t-18 four speed (does not include transfer case) pulled from 78 f-250 goes through all gears and rotates fine all gears working however looks like might have been filled with grease??????? or just burnt oil anyway unknown true condition $45.00 since i don't know just how good it is but may just need to be flushed out.
Keep in mind anything here is you want in better condition i am willing to rebuild and sell in perfect working order just higher price hope i have something you need always willing to haggle if you don't like prices but hopefully they are reasonable so help me sell something.
. So I want to get that fixed for him.
